Current Sensing Relay
6 years 11 months ago - 6 years 11 months ago #620 by Mark
Current Sensing Relay was created by Mark
Current sensing relays are found on most aircraft types. A common use for them is verification of pitot/static heating systems.
When pitot/static devices have the heat turned on, one leg of the heater element is passed through the sensing coil of the relay. With current present, the relay energizes and turns off any associated lights or warnings.
When troubleshooting a heating system, the device heater coil can usually be verified by continuity checking from the relay itself.
6 years 10 months ago #637 by jake ounce
Replied by jake ounce on topic Current Sensing Relay
The two Green wires are connected to the meter?
6 years 10 months ago #638 by Mark
Replied by Mark on topic Current Sensing Relay
Yes
Time to create page: 0.567 seconds
