ACSS Transponder with ADS-B Failure
6 years 7 months ago - 6 years 7 months ago #657 by Mark
We had a failed ADS-B function of the left transponder system.
This was seen on the control head (bad image, but light indicates ADSB).
An ADS-B fault light was also present on the face of the transponder while performing a self test.
The problem was a failed GPS receiver in the cabin overhead.
This unit is manufactured by CMC Electronics . It provides highly accurate GPS positioning information to the transponders. The FMS's (Flight Management Systems) can also use positioning information from these receivers for GPS approaches and landings.
Last edit: 6 years 7 months ago by Mark.
6 years 7 months ago #658 by Clipper
The internal troubleshooting ability of these modern electronics is amazing...atleast when it works the way its supposed to! And theres a reason there is redundancy built in! It appears there are 2 units ,is ADS-B a redundant system in all aspects?
6 years 7 months ago #659 by Mark
Two of everything..... to ATC units each being fed data from it's own GPS receiver.
Time to create page: 0.729 seconds
