Easy 28
9 years 4 months ago - 9 years 4 months ago #409 by Mark
Easy 28 was created by Mark
It might look cheap, but if a quick supply of 28 VDC is needed, it works great. This is mainly used as a "off aircraft" tester for relays, solenoids, and bulbs. Power is limited, using it on larger items is not recommended.
Having a bench 28 VDC power supply available for testing is still the preferred method.
See it in action.
Last edit: 9 years 4 months ago by Mark.
6 years 10 months ago #631 by jake ounce
Replied by jake ounce on topic Easy 28
Wonderful tool to have, thanks Mark!!
6 years 10 months ago - 6 years 10 months ago #632 by Mark
Replied by Mark on topic Easy 28
Tried to use it on a A/C contactor coil. It didn't work. You could here a click.... but it didn't close.
rotate.aero/forum/ata24-767/347-ata-24-40-external-power
Last edit: 6 years 10 months ago by Mark.
Time to create page: 0.651 seconds
