ELT performance
3 years 1 month ago - 3 years 1 month ago #1275 by dynamics
ELT performance was created by dynamics
Regarding two pages of Artex B406 ELT Manual I have just emailed, would you explain thoroughly what is the principle of the performance test and? What is the Attenuator? What is measured by the measuring device? Why operational Test should be done within the first 5 minutes of the hour?
Last edit: 3 years 1 month ago by dynamics.
3 years 3 weeks ago - 3 years 3 weeks ago #1278 by Mark
Replied by Mark on topic ELT performance
I've used one of these before.....
elttesters.com/gadss-tester-gt-1.html
Attenuation is the reduction in signal strength. Usually a load resistor is used for this purpose.
During test, you don't want the signal being broadcast out if possible. The 121.50 signal is just a warble tone. The 406 is a data burst with all the aircraft information. This includes the registration number and lat/long position if the IRU's are up.
Doing the test at the top of the hour is a standard for just about everyone using ELT's. Emergency services realize a non-continuous signal 5 minutes before to 5 minutes after the top of the hour is just a test.
Using a tester as above (direct hook-up) prevents all external transmission.
Last edit: 3 years 3 weeks ago by Mark.
3 years 3 weeks ago #1279 by Mark
There is nothing preventing you from calling the tower before the test. Just a common courtesy to let them know to ignore the warning.
Time to create page: 0.832 seconds
