Engine trouble shooting
3 years 3 months ago - 3 years 3 months ago #1193 by dynamics
Mark, what is test sheet with regard to troubleshooting of engine?
Last edit: 3 years 3 months ago by Mark.
3 years 3 months ago #1194 by Mark
Replied by Mark on topic Engine trouble shouting
I'm not sure what you mean by "Test Sheet".
For troubleshooting tips we use the FIM or Fault Isolation Manual.
There is a test procedure (or required tests to be performed) after certain engine components have been changed.
I'm sure the 737 has a sheet for engine parameters during high power runs.
A lot of the engine troubleshooting information on this site can be carried over to other engine types. They all do the same things with the same indications. The big difference is engine control..... the old MEC (Main Engine Control) mechanical unit or a FADEC controlled engine using an HMU (Hydro-Mechanical Unit) for fuel scheduling, VSV (Variable Stator Vane), and bleed valve positioning.
Time to create page: 0.626 seconds
