Climatic Chamber
3 years 6 months ago #1024 by dynamics
Climatic Chamber was created by dynamics
Mark, would you mind explaining what is climatic chamber(Cincinnati SUB Zero MCB-1.2-.33-H/AC)
3 years 6 months ago #1025 by Mark
Replied by Mark on topic Climatic Chamber
We're out of my range of knowledge.....
www.atecorp.com/products/cincinnati-sub-zero/mcb-12-33
The Cincinnati Sub-Zero MCB-1.2-.33-.33-H/AC MicroClimate Test Chamber simulates a wide range of temperature conditions. CSZ MicroClimate test chambers are designed to provide users with a compact chamber for testing small components and products for a variety of industries. Whether the task is temperature cycling tests or exposing a product to steady-state temperature environments, CSZ MicroClimate chambers will maintain precise and accurate temperature control throughout the test. The Cincinnati Sub-Zero MCB-1.2-.33-.33-H/AC has a benchtop and reach-in model to fit your laboratory testing needs.
The compact size of the Cincinnati Sub-Zero MCB-1.2-.33-.33-H/AC MicroClimate test chamber saves precious workspace and makes it useful for testing small components and products. Each CSZ chamber is constructed with fully welded seams and ports to prolong chamber life. In addition, each Cincinnati Sub-Zero MCB-1.2-.33-.33-H/AC chamber is inspected at each point of the production process and fully tested to assure the customer gets a reliable instrument. This chamber model's temperature range is -30 to 190 °C and offers easy installation at any location.
Time to create page: 0.737 seconds
