ICAO Annex 6
3 years 7 months ago #968 by dynamics
ICAO Annex 6 was created by dynamics
Mark,with regard to Part I Chapter 7, Para 7.2.5. of subject document do you have any idea about avionics instruments/systems used in b737 family for following purposes:
1 -altitude alerting system
2-An automatic altitude control system
3-A secondary surveillance radar  (SSR) transponder  with altitude reporting system that can be connected to the altitude measurement system in use for altitude keeping
3 years 7 months ago #975 by Mark
Replied by Mark on topic ICAO Annex 6
All of these user systems (Altitude Alert, Altitude Control, and ATC Transponders) use the outputs from the Air Data Computers.
The Air Data computer(s) uses 3 or more 429 output buses to feed air data information to much more than just the systems listed above. Cabin altitude control, Auto-Pilot, FMS (Flight Management Systems), Yaw Damper, Aileron Lockout, Flap Limiting, Elevator Feel, Rudder Limiting are just a few air data user systems.
The Air Data computers receive pitot/static pressures from two pneumatic hookups. They also receive information from the AOA (angle of attack) and TAT (total air temp) probes. I would guess the number of 429 output labels to exceed 60.
A couple of images that might help explain a 429 data bus output are below.
Time to create page: 0.836 seconds
