Nose gear load control
3 years 8 months ago #879 by dynamics
Given tail down landing condition, when we hear hard landing, frequently our focus is directed more toward extreme loading on main gears,however full or nearly full control column application before nosegear touchdown can produce heavy loads on the nosegear and its support structure so the question arises is that can we monitor pitch rates generated before nosegear touchdown from signals which are sent from gyro's  in inertial reference system to FDR?
3 years 8 months ago #880 by Mark
Replied by Mark on topic Nose gear load control
Absolutely..... all pitch, roll, yaw data from the Inertial Reference Units along with accelerometer data go to the DFDAU (Digital Flight Data Acquisition Unit). It is then sent to the Flight Recorder.
You can download the data directly from the recorder. Some DFDAU's have a PCI Express card slot installed. If your aircraft have that type of DFDAU, you can pull the card and take data from it also.
I don't have a picture of the card slot, but it would be on the the right side of this image if it was visible.
3 years 8 months ago - 3 years 8 months ago #881 by dynamics
Replied by dynamics on topic Nose gear load control
Thank you Mark, however I can not rely on the accelerometer data since they are acceleration of the A/C c.g which is close to touchdown point of main gear along the center line of A/C so the acceleration component of the c.g which is due to angular acceleration as a result of full application of control column would be small and therefore are error prone, by the way although I am more optimistic about RLG (ring laser gyro's) in IRU, but I need to develop detail performance model of RLG to figure out its error (e.g g-sensetive misalignment errors) while the only available information is the P/N and vendor cage code in part catalogue! so would you mind advising me how can I get more detail data about RLG structure/performance?
Last edit: 3 years 8 months ago by dynamics.
3 years 8 months ago #882 by Mark
I do not have access to engineering level documentation, but I did find this online.....
3 years 8 months ago #883 by dynamics
Mark, I am so thankful for you in my life...............
3 years 8 months ago - 3 years 8 months ago #884 by Mark
Just doing what I can.....
Aircraft maintenance folks helping each other out.
It's what the site is all about!!
Last edit: 3 years 8 months ago by Mark.
Time to create page: 0.812 seconds
