Parity error-2
1 year 4 months ago - 1 year 4 months ago #1765 by Mark
Replied by Mark on topic Parity error-2
What you sent doesn't seem to fit in with your previous issue on the SGU.
It's talking about the Flight Mode Annunciators, but I understand where you're trying to go with this as a comparison to your original problem.
Your reference is talking about SSM in relation to a 429 bus. It is saying the identifier for parity is wrong..... just like your SGU fault.
You need to verify the jumpers on the SGU rack. One is broken or open. It could be a pin pushed back, a wire broken off the back of the pin, or a wire is broken or disconnected from the junction splice. These can be checked with a Ohm meter. Start pinning the rack to find out which pin doesn't have continuity to the rest of them in the group. YOU MUST HAVE A "ODD" NUMBER OF JUMPERS CONNECTED.
Last edit: 1 year 4 months ago by Mark.
1 year 4 months ago #1766 by Mark
This is a typical 767 SGU. The pins circled are parity pins. These go to ground, but it doesn't matter if they're hooked to each other also.
You need to find the pins on the prints for your aircraft and find out if one is not connected.....
1 year 4 months ago #1771 by dynamics
Replied by dynamics on topic Parity error-2
How might I determine which pin on the Electronic Flight Instrument System serves as the programming pin?
1 year 4 months ago #1772 by dynamics
Which of the following three hexadecimal codes is the correct one for the aircraft?
parity error
check the SG program pin configuration
F93919D
873EC0A
C080000
1 year 4 months ago #1773 by Mark
Any ground pin not associated with power or case ground.
It's never just "one" pin. It's several and their total number (odd or even) is the parity.
1 year 4 months ago #1774 by Mark
I cannot answer your question on the hex codes.
Those are in your Maintenance Manual.
1 year 4 months ago #1775 by dynamics
Which of the following three hexadecimal codes is the correct one for the aircraft, in reference to the file I have just attached to the email?
parity error
F93919D
873EC0A
C080000
1 year 4 months ago #1776 by Mark
Has anybody gone out a checked the pins on the aircraft?????
Looking at manuals isn't going to fix the problem.
Get a meter and your wiring prints and check the parity pins. One is broken. Find it. Fix it.
Time to create page: 0.956 seconds
