ADS-B out
1 year 9 months ago #1678 by dynamics
ADS-B out was created by dynamics
How to know if a particular aircraft is ADS-B equipped through inspection?
1 year 9 months ago #1679 by OG GarlicSalt
Replied by OG GarlicSalt on topic ADS-B out
Set the aircraft up for a flight input the information and see if it comes up on the ADS-B radar.
Other way would be if you can check for MODE-S Transponders required for ADS-B. Also possibly but PN of GPS antenna, if it was changed to accommodate ADS-B Out.
I'm sure there are other ways to check as well.
1 year 9 months ago #1681 by dynamics
Replied by dynamics on topic ADS-B out
Would you mind explaining which components/equipments have to be added, and which components have to be modified in order to install ADS-B out system in 737-300 airplane?
1 year 9 months ago - 1 year 9 months ago #1682 by OG GarlicSalt
This is from my head and I cant comment exactly on 737, but for 767, there is a wiring change to the Flight Deck Pedestal, GPS antenna are replaced, and the Transponders are changed. I think the MMR is changed as well but i'm not 100% sure on that.
There is probably a way to check through the FMC ATC page it shows the ADS-B.
Last edit: 1 year 9 months ago by OG GarlicSalt.
1 year 9 months ago #1683 by dynamics
What is CPDLC(CONTROLLER PILOT DATA-LINK COMMUNICATIONS)? How does it(CPDLC) differ from ADS-B out?
1 year 9 months ago #1684 by OG GarlicSalt
Again this is getting into pilot territory and there are different setups. Typically your CPDLC can be accessed from the FMS(MCDU) or ACARS unit if your aircraft has one.
1 year 9 months ago #1685 by Mark
Replied by Mark on topic ADS-B out
Can I get a picture of control panel, please.
Maybe one of the transponder also.
1 year 9 months ago - 1 year 9 months ago #1687 by dynamics
which panel do you need a picture of?
Last edit: 1 year 9 months ago by dynamics.
1 year 9 months ago #1688 by Mark
The actual ATC control panel in the pedestal. A picture of the Transponder (and part number) in the electronics rack.
1 year 9 months ago #1689 by dynamics
I can not upload the picture, so may I request you to kindly explain how I can verify that ADS-B out system is installed from appearance of the control panel and part number of the transponder.
Time to create page: 0.782 seconds
