Wire Shielding
2 years 1 month ago - 2 years 1 month ago #1577 by dynamics
Wire Shielding was created by dynamics
Where is wire shielding necessary in aircraft ? and where is it prohibited?
Last edit: 2 years 1 month ago by Mark.
2 years 1 month ago #1578 by Mark
Replied by Mark on topic Wire shielding
Wire shielding is used to protect signal wires. 429 data bus twisted pairs, sensor outputs, co-ax communication wires.....
Shielding keeps outside inductance from close proximity wires from interfering with those shielded signals.
Shielding is normally grounded one one/both ends. Induced inductance is routed to ground.
The use of shielding is strictly an engineering function. I know of no prohibited reasons. Shielded wires add weight to the aircraft, which would be the driving reason of whether to use it or not.
Time to create page: 0.836 seconds
