ATA 34-10, Pitot Probe R/R
9 years 8 months ago - 9 years 8 months ago #292 by Mark
No pitot heat for the left probe on a King Air.
The probe assembly can be split open in the middle which allows access to the electrical connector. The probe side read open with ohm-meter.
The pneumatic connection is accessed by pulling the mount plate off the aircraft.
New probe coil resistance.
The bleed hole (which must be covered for a leak check) was located quite near the tip of the probe itself.
Good leak check...... good heat...... good to go!!
Last edit: 9 years 8 months ago by Mark.
Time to create page: 0.869 seconds
