767 Auto-Throttle Ground Test
1 year 9 months ago - 1 year 9 months ago #1676 by Mark
A ground test of the A/T's can only be done with the engines running. On the FMC, go to the takeoff page. Put 60 in the scratch pad and then move that into the thrust setting with the (left) side button.  That will give you a max de-rate for the day. Flaps at 5, then push the N1 button on the MCP. The autopilot does not have to be engaged and the EEC's can be on or off. The N1 bug select on the EICAS panel has to be pushed down (not in manual mode). Only the takeoff mode will work in the TMC.
Last edit: 1 year 9 months ago by Mark.
1 year 9 months ago #1677 by OG GarlicSalt
Mark,
I've actually not done to much work on the auto throttle, but what is driving this test? What's tested here that's not tested on MCDP test 10(or whatever is the auto throttle test).
1 year 9 months ago - 1 year 9 months ago #1693 by Mark
Replied by Mark on topic 767 Auto-Throttle Ground Test
The normal takeoff procedure is to manually take the engines to 70% at the beginning of the roll. At 70% the "N1" button is pushed which causes the TMC to takeover the rest of the throttle control.
We had a aircraft abort takeoff because "N1" didn't engage (I don't know why they just didn't take it, but I don't fly these things. I'm assuming safety is the issue).
We tried the test above when we could find no other issues with the aircraft. It worked, got signed off, and hasn't had a problem sense.
Time to create page: 0.749 seconds
