ATA 21-31, Outflow Valve Operation
4 years 4 months ago - 4 years 4 months ago #805 by Mark
Checking the outflow valve operation in "Auto" mode is quite simple. No switching to air mode or other prerequisites required.
Drive the "Landing Altitude" setting to below field elevation (or just crank it all the way down), push the throttles forward...... the valve should close. Pull back on the throttles..... it will open.
The resistance of the position potentiometer inside the valve is approx... 10.7K ohms.
And could be easily substituted with a 10K ohm potentiometer like the one below for troubleshooting purposes.
Last edit: 4 years 4 months ago by Mark.
4 years 4 months ago #806 by Mark
Or..... just push the throttles forward.
Tried it without messing with the landing altitude setting. Same results!
Time to create page: 0.700 seconds
