Anything quick tips that might be helpful to others. Longer entries can be directed towards the forum.
Subcategories from this category:
Airbus, McDonnell Douglas, Boeing, Gulfstream, Falcon
Load Light
One way of checking for intermittent opens in signal or power wires is to use a load light at the plug that connects to the failed unit.
First of all, it will prove if a wire can handle the amperage load. Second, it gives you a visual indication of wire integrity while shaking down the wire bundle(s) that it runs through.
In this case, we had a 767-200 with a year long history of Thrust Reverser failures. This is a hydraulically driven system. It requires that the Isolation Valve in the pylon and two Sync Locks at the bottom of the engine have 28 VDC to operate. Lifting the T/R handle in the cockpit provided this power.
We opened some wing underside panels along with a top side panel above the pylon. We shook down everything we could get or hands on.
At no time did any lights flicker. No fix this time, but we've had luck using this method in the past.
Continue reading
  1919 Hits
767 APU Hung Start
 767 APU Hanging at 30% During Start
FlowSensing 0420During the APU engine start, the IGV (Inlet Guide Vanes) are supposed to be closed. This allows all incoming air to be directed into the combustion chamber. After start with a air demand (main engine start or air conditioning pack operation), the IGV vanes open allowing bleed air output.
We purposely pulled the IGV actuator arm out (vanes open) to see if it would would close them on initial rotation. It did not.
With the drain on the air bleed system, the APU could not accelerate beyond approximately 30% and it would shut down.
More troubleshooting here.
Continue reading
  5199 Hits
